Bulgin Connectors - Waterproof Kits
A range of quality plugs and sockets manufactured by Bulgin in glass filled nylon to military specification and waterproof to IP68 ensuring trouble free cable connections on deck. Blanking caps supplied which doubles as an assembly tool. Suitable for AC/DC and for cable diameter 5-9mm. The kits are packaged as a plug & socket pair with caps and Stainless Steel fixing screws.
Plug & Low Flange Socket
  • Part no.
  • B-DP2
  • B-DP3
  • B-DP4
  • B-DP6
  • B-DP7
  • B-DP9
  • B-DPBNC50
  • B-DPBNC75
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
Technical Information
Plug & In Line Socket
  • Part no.
  • B-DP2 IL
  • B-DP3 IL
  • B-DP4 IL
  • B-DP6 IL
  • B-DP7 IL
  • B-DP9 IL
  • B-DPBNC50 IL
  • B-DPBNC75 IL
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
Plug & Bulkhead Socket
  • Part no.
  • B-DP2 BH
  • B-DP3 BH
  • B-DP4 BH
  • B-DP6 BH
  • B-DP7 BH
  • B-DP9 BH
  • B-DPBNC50 BH
  • B-DPBNC75 BH
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
