Cable Glands - 316 Stainless Steel
The DG Series stainless steel cable glands are made from marine grade 316 stainless steel.They are available in an aperture range of 8mm to 50mm and have an attractive, low profile shape. The range has passed independent rigorous dust and waterproof testing to IP 68. Each unit is supplied with clear fitting instructions and A4 stainless steel fixings. DG Deck Glands are easy to fit and do not require the removal of fitted connectors when installing.
More Info
Fitting Instructions
DG8S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 35ø x 12mm
  • 2.5-6mm
  • A1-DG8S
DG20S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 49ø x 19mm
  • Drill to suit
  • A1-DG20S
DG21S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 49ø x 19mm
  • 4.5-9mm
  • A1-DG21S
DG22S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 49ø x 19mm
  • 9-14mm
  • A1-DG22S
DG30S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 60ø x 19mm
  • Drill to suit
  • A1-DG30S
DG40S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 70ø x 19mm
  • Drill to suit
  • A1-DG40S
DG45S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 70ø x 19mm
  • 12-15mm
  • A1-DG45S
DG50S
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 84ø x 23mm
  • Drill to suit
  • A1-DG50S
