Cable Glands - DG Coax Kits
Six kits for the installation of VHF radios supplied with either a BNC or PL259 coax connection. Each combines the DG gland (plastic, aluminium or stainless) with a 4.5mm split seal which does not require the removal of fitted connectors during installation (suitable for RG58 type coax cable). Full assembly instructions included.
More Info
Fitting Instructions
DGKIT1P
- Material:
- Dimensions:
- Cable Size:
- Connector Type:
- Part Number:
- Nylon
- 49ø x 19mm
- 5mm
- BNC
- A1-DGKIT1P
DGKIT1A
- Material:
- Dimensions:
- Cable Size:
- Connector Type:
- Part Number:
- Anodised aluminium
- 49ø x 19mm
- 5mm
- BNC
- A1-DGKIT1A
DGKIT1S
- Material:
- Dimensions:
- Cable Size:
- Connector Type:
- Part Number:
- Stainless steel
- 49ø x 19mm
- 5mm
- BNC
- A1-DGKIT1S
DGKIT4P
- Material:
- Dimensions:
- Cable Size:
- Connector Type:
- Part Number:
- Nylon
- 49ø x 19mm
- 5mm
- PL259 plug x 2 + inline
- A1-DGKIT4P
DGKIT4A
- Material:
- Dimensions:
- Cable Size:
- Connector Type:
- Part Number:
- 49ø x 19mm
- 5mm
- A1-DGKIT4A
DGKIT4S
- Material:
- Dimensions:
- Cable Size:
- Connector Type:
- Part Number:
- Stainless steel
- 49ø x 19mm
- 5mm
- A1-DGKIT4S
