Cable Glands
The new DG series of Cable Glands offers the best possible watertight solution for all cable and pipe transits. The attractive, low profile shape comes in an aperture range of 8mm to 50mm and is available in UV stable nylon, aluminium and in response to customer requests for a high polish fitting for luxury yachts, 316 stainless steel. The range has passed independent rigorous dust and waterproof testing to IP68. Each unit is supplied with clear fitting instructions and A4 stainless steel fixings. DG Cable Glands are easy to fit and do not require the removal of fitted connectors when installing.
Index Marine manufactures and supplies a wide range of electrical installation equipment through its network of distributors in Europe and in the USA.
