Waterproof Buccaneer Connectors - Single
A range of quality plugs and sockets manufactured by Bulgin in glass filled nylon to military specification and waterproof to IP68 ensuring trouble free cable connections on deck. Blanking caps supplied which doubles as an assembly tool. Suitable for AC/DC and for cable diameter 5-9mm. Packaged as separate plugs and sockets with caps and stainless steel fixing screws.
Plugs
  • Part no.
  • B-DP2P
  • B-DP3P
  • B-DP4P
  • B-DP6P
  • B-DP7P
  • B-DP9P
  • B-DPBNC50P
  • B-DPBNC75P
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
Technical Information
Bulgin Plugs
Low Flange Sockets
  • Part no.
  • B-DP2S
  • B-DP3S
  • B-DP4S
  • B-DP6S
  • B-DP7S
  • B-DP9S
  • B-DPBNC50S
  • B-DPBNC75S
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
Bulgin Plugs
Bulkhead Sockets
  • Part no.
  • B-DP2SBH
  • B-DP3SBH
  • B-DP4SBH
  • B-DP6SBH
  • B-DP7SBH
  • B-DP9SBH
  • B-DPBNC50SBH
  • B-DPBNC75SBH
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
Bulgin Plugs
In Line Socket
  • Part no.
  • B-DP2SIL
  • B-DP3SIL
  • B-DP4SIL
  • B-DP6SIL
  • B-DP7SIL
  • B-DP9SIL
  • B-DPBNC50SIL
  • B-DPBNC75SIL
  • Pins
  • 2
  • 3
  • 4
  • 6
  • 7
  • 9
  • 50Ohm
  • 75Ohm
  • Amp
  • 10
  • 10
  • 6
  • 3
  • 3
  • 5
  • Connection
  • Screw
  • Screw
  • Screw
  • Screw
  • Screw
  • Solder
  • Crimp
  • Crimp
Bulgin Plugs
