Cable Glands - Plastic
The DG series plastic cable glands are made from UV stable nylon. They are available in an aperture range of 8mm to 40mm and have an attractive, low profile shape.The range has passed independent rigorous dust and waterproof testing to IP 68. Each unit is supplied with clear fitting instructions and A4 stainless steel fixings. DG Deck Glands are easy to fit and do not require the removal of fitted connectors when installing.
More Info
Fitting Instructions
DG8P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 35ø x 12mm
  • 2.5-6mm
  • A1-DG8P
DG20P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 49ø x 19mm
  • Drill to suit
  • A1-DG20P
DG21P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 49ø x 19mm
  • 4.5-9mm
  • A1-DG21P
DG22P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 49ø x 19mm
  • 9-14mm
  • A1-DG22P
DG30P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 60ø x 19mm
  • Drill to suit
  • A1-DG30P
DG40P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 70ø x 19mm
  • Drill to suit
  • A1-DG40P
DG45P
  • Dimensions:
  • Cable Size:
  • Part Number:
  • 70ø x 19mm
  • 12-15mm
  • A1-DG45P
