Ethernet Technical Information
Cat 5e compliant with data rates up to 100MHz
Shielded system with high noise immunity and EMI protection
Cat 5e shielded coupler maintains shielding
Shroud on RJ45 protects from abuse and mis-mating
Screw coupling provides a proven and secure locking system
Rewireable version gives ability to ‘field’ terminate
Data rate up to 100MHz
RoHS compliant
Dimensions
  • Part no.
  • ETN100P
  • USB 200S
  • USB 250S
  • Diameter
  • 38.1mm
  • 38.1
  • 44.5 x 44.5mm
  • Length/Height
  • 77.5
  • 33mm
  • 33.5mm
  • Mount Dia
  • 27mm + locating notch
  • 26mm
  • Height above panel
  • 7.5mm (ex Cap)
  • 10.75mm
